What materials are needed to seal the iPad 2 front panel?
http://www.ipadscreenrepair.com/wp-conte...
this will show you where to put the pre-cut 2 sided tape for the ipad 2- very helpful! Good luck!
このアンサーは役に立ちましたか?
If there is adhesive left from removing the front panel (assuming that is why you need to seal it?) you can reheat it using a Heat Gun until it gets sticky, then place the front panel back on.
Hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 3,334
