メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Is this a faulty battery?
Hey guys, I recently replaced my Macbook pro 13” early 2015 battery and wanted to ask if this looks like signs of a faulty battery.
Upon installation I fully drained and recharged the battery and capacity showed to be 99%. After a few days (around 5 or 6 cycles), the battery capacity dropped from 99% to 94.6% mid-use while the computer was pretty warm.
On the next charge, my Macbook randomly shut off on its own mid-use again while at 70% charge. Turned it back on and kept using it, no noticeable difference in performance or battery life and didn’t shut off again since then. Now Im going on 9 cycles and according to Coconutbattery and Macbook finder the battery condition is “normal” and still at 94.6% capacity (so far). Manufacturer shows as SMP.
The battery performance itself looks to be fine and I’m getting a decent charge out of it (at least seemingly better than before), however when running apple diagnostics I’m getting the message PPT004 battery needs service. Should I be looking to replace it again? I’m also still on OSX 10.10
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Yes, it sounds very much like a battery issue. I am guessing it is not a Genuine Apple battery.
Try to drain it completely before charging it up again to full, but I suspect only an original battery will take that error away in diagnostics.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Return the battery as its defective!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Gent Zalli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 169
