メインコンテンツにスキップ
2017年に発売されたAppleの第3世代スマートウォッチです。オプションで通信機能が付いています。
196回答 すべてを表示
Apple Watch Wont Turn On After Trying to Fix Adhesive
Okay so I was stupid for doing this and it was my first time messing with apple watches internally. I was following ifixits guide but was scanning through and didnt see that the cellular watches battery connector is in a different spot so i unplugged the screen while the battery connector was still plugged in(the watch was turned off) and then i may have slighty scratched the surface of the screen connectors when trying to pull them out but I dont know if this actually affects them or not(its just a small scratch on the cable), but know the screen wont turn on at all and I just feel it vibrating and stuff, what do you think happened to it? Thank you in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The most likely issue, if all of the ribbon cables have been properly seated back into their connectors, is that a ribbon cable was damaged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lanerfloyd107 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 60
