Macintosh HD will not show up in the Copy section in order to clone?
Macintosh HD will not show up in the Copy section using SuperDuper! in order to clone any idea how I can fix this before I install new ssd?
First do not clone! Cloning was great in its day. But with the advent of the repair partition is not the way to go today. First do an external Time Machine backup. Now install the system on your new drive after format it for Mac. Now use Migration Assistant to move your settings, Apps and user data. You will now have a working repair partition.
このアンサーは役に立ちましたか?
Ok but I did start the clone using carbon copy instead and it’s in the middle of it now….should I stop it and do what you said or is it ok to continue what I’m doing as long as cloning will work for me
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 29
