メインコンテンツにスキップ
Repair and disassembly information for amplifiers in home audio systems.
117回答 すべてを表示
VSX819H amp wont enter service mode
Hi, My pioneer VSX 819h went into protection mode. It now won’t enter service mode. I’m following the service manual. The only thing it does is turns on for 4-5 secs when pressing power button+adv-surround which according to the service manual is used for clearing the error counts. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Until you resolve the protect mode, the amp will continue to work as you see it. Protect usually indicates that there is a short in the output section and the amp shuts down to prevent further damage. Since this amp uses discrete transistors for outputs, check each one for a short. Once found, change the entire pair (2SD and 2SC transistors) and any other components in the area that are effected.
Dan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ThreeTwoBravo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 156
