メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2012年6月12日に発売。Turbo Boost付きのインテルプロセッサー、モデル番号は A1278。
1603の回答 すべてを表示
MacBook Pro wouldn't accept RAM upgrade.
Last month I tried to upgrade my Mom’s 2012 MacBook Pro with this RAM - Crucial 8GB Kit (4GBx2) DDR3/DDR3L 1600 MT/s (PC3-12800) SODIMM 204-Pin - CT2K4G3S160BM. It would run for a bit but then crash and never figured out why. The attached picture is the specs for her Mac. I’ve searched all over google for an answer and can’t figure out why it failed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
選択されたソリューション
Replace the old RAM first and get the machine running. Next replace just one stick of the new RAM and see if it works. Now try the new stick in the other slot. This checks both the RAM and the slot. Repeat with the second stick.
Are you getting any beep tones?
UPDATE
RAM Type:PC3-12800 DDR3LMin. RAM Speed:1600 MHz
Details:Supports 1600 MHz PC3-12800 DDR3L SDRAM SO-DIMMs (204-pin).
Standard RAM:4 GBMaximum RAM:16 GB*
https://everymac.com/systems/apple/macbo...
この回答は役に立ちましたか?
スコア 2
コメント:
I have done what you've said with swapping the sticks before with no luck. It did make a beep tone once it crashed the Mac and I tried to reboot it, which it wouldn't allow it to reboot.
さんによる
Did it work with the old RAM in place?
さんによる
@mayer it would crash regardless of the combination. So any combo of either old or new caused it to crash too. It does not crash with both old sticks installed though
さんによる
At this point my best guess would be that the new RAM is faulty or has received ESD damage. Meanwhile, try pulling the old and booting with just one stick of the new RAM. Try it in both slots. Now do the other stick and see if you can identify if both are faulty.
さんによる
@mayer Alright, I'll have to try that. Thanks for your help, appreciate it.
さんによる
コメントを追加
That RAM should work fine. There must be something wrong with it.
この回答は役に立ちましたか?
スコア 0
コメント:
I'm starting to think the same thing
さんによる
コメントを追加
Try reseating the ram. This means taking it out and putting it back in. I would also take an air duster to the slots to remove any dust. If it still crashes, then your ram sticks may be faulty. If they are still under warranty, you can return the faulty ram and you should get a replacement.
この回答は役に立ちましたか?
スコア 0
コメント:
I have already done what you've suggested. You might be right about the stick(s)being faulty. Thanks for your input
さんによる
コメントを追加
回答を追加する
Jarad Turner さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 70
