メインコンテンツにスキップ
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
197回答 すべてを表示
Adding Samsung SSD 970 Pro M2 to Mac Mini 2014 with factory HHD
Hi everyone,
I've an old Mac Mini (2014) with the original “Apple HHD“ HD.
I’d like to upgrade it for better performances installing an SSD but since i’m frightened of taking apart the whole machine i’m considering to buy a SAMSUNG SSD 512 GB 970 PRO M. 2
I have two questions though:
1) Is the Samsung SSD 970 Pro M2 PCIe suitable for my mac mini?
2) Is it possible to have both original HHD and the mentioned PCIe installed in the machine or it’s better to replace the old HHD with a brand-new SSD?
Thank you in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Actually I upgraded my mini (i5 2.6Ghz, 8gb RAM) with Samsung 970 pro myself. It was super easy: I bought an adapter for 8$ (with free shipping and tools) and installed it with this nvme added to it. In my mini, it works just perfectly, with speeds just above the 700 MB/s (that’s only because of mini bus limitations). But it’s still 2 times faster than my simple SSD which I have in the place of the old HDD. And now I have two discs in place. So I just love this solution, as it made my mac mini much more usable, at least for a few years ahead.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Its not Apple approved ;-}
さんによる
コメントを追加
Sadly, Apple uses a different connector than the M.2 blade SSD’s. While some have managed to use an adapter to convert a M.2 SSD to work I really don’t recommend it.
While Apple SSD’s are a bit more expensive I would recommend you go with one of them or either a OWC or Transcend custom SSD’s which better match the Apple SSD’s
Here’s a good source of info and supply of the custom Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs and here’s the guide to follow Mac mini Late 2014 SSDの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Unlikely without an adapter, best would be to get a good SSD with SATA interface.
You can only have 1 disk (either SSD or HDD) . Read the guide carefully - Step 34
Mac mini Late 2014のハードディスクドライブの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Giulio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,613
