Can I use it as a display?
The computers logic board is finished, how can I rig it to work only as a display?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
In short you can't, no easily. You'd need to disassemble and figure out a way to connect the cable that normally goes to the logic board to some sort of adapter. My french is horrible but apparently this thread http://forum.macbidouille.com/index.php?... is all about figuring that out. good luck.
このアンサーは役に立ちましたか?
No, It can be used only as output for the motherboard. You may want to think about getting another Motherboard.
Tim
このアンサーは役に立ちましたか?
You might be better off selling the unit for parts, and taking the money to buy a new 20" monitor :(
You'll probably end up with some leftover cash in the process!
このアンサーは役に立ちましたか?
I agree with David, its much simpler and you'd be better off selling it for parts (if iFixit for example!) and then putting that money into a real, newer display.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,598
