メインコンテンツにスキップ
Ripped off power supply from motherboard. Is this fixable?
So I ripped the power supply adapter off the motherboard and I couldn’t find any other person with this type of problem. There are no soldering points, and I need to know if this is fixable or if the motherboard is just trashed. Thanks for the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yes this can be repaired, but not easily unless you have experience. The pads must be repaired before the connector is reattached. Also, there will need to be additional support for the connector otherwise it will easily be torn off again. This is not a repair that should be attempted without prior experience. Contact a local repair show and bring along the connector and the board (in a static bag).
Dan
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Richard Chatt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 435
