Screen 80% unreadable from an impact dent.
Is there a way to view what is on the screen somehow with another laptop or screen?
I cannot change any settings since I cannot see where the cursor is.
You’ve got displayport on that model so you can hook it up to an external monitor.
このアンサーは役に立ちましたか?
will the screen come up automatically? or do I need to click on something.
the problem is that i can't see to click on anything.
Should do. You should at least get something on screen then you can secondary click to get to settings
Replacing the display assembly is not overly hard MacBook Air 11インチ Late 2010ディスプレイアセンブリ交換 and here’s the needed part MacBook Air 11" (Late 2010) Display Assembly
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 38
