メインコンテンツにスキップ
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497回答 すべてを表示
Washer fills and drains but won't agitate or spini
important note: this is about the series 100 washer, not 110. there wasn't an option for the 100
when put on a wash cycle, it will fill and drain repeatedly and won't agitate. when put on a spin cycle, it will spin.
There's no way it's the lid switch, because the washer won't start to fill if the lid isn't closed, and it fills when the lid is closed.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Please give us the exact model number so we can better answer your question.
さんによる
110. 24946300
さんによる
Hi @ Kim Forest
What is the problem with your washer?
If it won't agitate, can you manually operate the agitator in both directions?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sounds like the “agitator dogs” these are under the center cap of the agitator. They are small plastic wedge looking things, may be 3 or 4 of them.
They cost at the most $10 or as low as $5 for all.
Grab the center piece in tub & turn it back & forth, at some point it should grab & not turn, if not you could probably feel the grinding of the bad dogs.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kad Ek さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 56
