Screen replaced and now proximity sensor, ear piece & mic not working
Hi all, please help!
I changed a broken screen for a friend on an iphone 7 using a screen complete with digitizer, ear piece, front camera etc from amazon.
The screen works fine but the problems I have are that the proximity sensor does not work, when you make a call you can not hear the other person and they cannot hear you, the speaker button is greyed out when calling and when you try and go onto facetime it just closes itself straight away.
Please Help! Thank you
この質問は役に立ちましたか?
5 件のコメント
Thank you, would this explain the proximity sensor not working either?
Tom Matthews さんによる
@Tom Matthews Hard to tell without the chance to have a look at what the condition was before replacement, but yes, proximity sensor is a part mainly made of glass and quite easy to break. Double check it's still attached to the flex cable and properly aligned, that's all that can usually go wrong in a replacement.
arbaman さんによる
A quick update, loosened off the screen and placed a bit of pressure where the audio ic is on the board, while doing this I've made a call and the speaker is no longer greyed out.
Took my finger away and it is still working, for how long it is unknown, but mic and speaker is back, siri and voice memo works, proximity sensor works fine now too
Tom Matthews さんによる
It was fixed short term, it is now broken again:(
Tom Matthews さんによる
@Tom Matthews I avoided to sound pessimistic but it's quite clear a rail cannot be fixed by pressure alone, it needs to be rebuilt reliably with a solid jumper wire.
arbaman さんによる
