Diagnostic LED's 3 & 4 not on
My iMac will power on but no chime or video. LED 1 is always on & 2 lights when start button is pressed. Fan runs. What does LED’s 3 & 4 mean?
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
"LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 368
2 件のコメント
Thanks for this.
So LED 1 & 2 lit but no chime probably means logic board fault?
Ah well - it’s good to know
Coxy さんによる
@scousecoxy No, it probably means a GPU failure.
mayer さんによる
