メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
How do I set up iPhone if home button is broken?
I just repaired the screen on an iPhone 7. Bought it off ebay to repair, was listed as having cracked screen and home button not working. Received the phone and turned it on before repair, assistive touch was on but home button didnt work. Replaced the display, put everything back together, and powered back on. Now assistive touch button is gone, but still stuck at the screen with “press home to open.” How do I get past this without assistive touch, and why did it just go away, I didn’t reset or anything. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
  1. Connect your iPhone, to a computer with iTunes installed.
  2. In iTunes, select your device.
  3. From the Summary pane, click Configure Accessibility in the Options section at the bottom.
  4. Select the Voice Over and click OK.
  5. Double tap on the Press home to open text.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
thanks it worked
さんによる
I am having the same issue. except my Mac doesn't have iTunes. I read that it's no more.
さんによる
@caleag On newer versions of MacOS the iTunes functionality has been moved to the Finder. Just open up Finder and locate your phone on the left side of the screen and you'll be in business.
さんによる
コメントを追加
Home bottom is broken then i cannot double tab on the home bottom
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If your setting jt up for yourself, restart it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if u need to get to the language menu turn on the phone then shut it off then u can turn it on and if will go to the sett up screen past the part where i need to press the home button
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If I understand right, your iPhone is setup just missing home button on screen ? Swipe from right to left for camera, make any picture, then open picture in camera. In top right corner you will have ALL PHOTOS - tap on it - and you should be on screen to unlock you Phone with code. Unlock it and from bottom menu you should be able to get into Settings (depend how is your menu setup - I have it there).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Garrison Bates さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 114
今までの合計 3,946
