メインコンテンツにスキップ
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
39回答 すべてを表示
Where can I get a replacement for my IO port
Someone tried to jam an ordinary headphone jack in there and ended up splitting the entire jack into pieces, i am unable to connect with the cable i just bought (and was hoping that it might still work but wasn’t expecting much). Where can i buy a new part for it? I can do the soldering myself but just need a new part.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
You can find replacement parts on places like Digikey, Aliexpress, and likely even Adafruit or Sparkfun. You’ll have to find a port with the correct footprint of course. If your port is too mutilated to tell, here’s some photos I referred from: top down view and close up. You’ll want a port that is 2.5mm and has 3 conductors and 3 contacts.
I don’t have the dimensions of the original port, however with some quick research, I found this port which looks like it should fit. The only issue is the back contact doesn’t line up with the contacts on the PCB. You can likely just solder a wire from the contact to the PCB however, if you look at some of the sites I provided above then you may be able to find a more suited part.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I was unable to find a replacement, so I took an orthodox approach; I soldered female pin headers to each of the 3 solder pads that the IO port would normally be soldered to and snipped off the end of my link cable, and soldered a male pin header to each of the 3 wires from the link cable.
While this method was a bit hackish and certainly not the prettiest thing in the world, I am now able to connect my ti 83 plus to my computer by simply connecting the 3 female connectors to their corresponding male counterparts.
EDIT: I eventually got the courage to give my calculator the repair it deserved. No more ugly wires coming out of the calculator!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
The Awesomer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 91
