not knowing that was 120volts l plugged it into 220volts so it blow
Please l gifted sony amplified fm stereo am receiver not knowing that was 120volts l plugged it into 220volts so it blow. Who to repair. Thank you
Was there any magic smoke? Did you hear/see something crackle inside when you plugged it in? Was there a bad smell?
If you’re daring enough, unplug the machine (If you haven’t already!) and pop it open. Take visual of the boards: if there’s anything that’s burnt or smells bad, or something out of place, something most likely failed.
Locate the power board. Usually the external AC cable plugs into this, and there’s probably a giant transformer on the board. Somewhere on there should be (hopefully) a fuse plug, and a fuse that is blown. Pop that bad boy out, take it to the hardware store, and find a 120V replacement.
After that, find a 220 to 110 V converter, plug the fuse in, and see if the machine works.
Good luck, dear.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
Hi,
What is the model number of the receiver?
jayeff さんによる
