メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2686回答 すべてを表示
iPhone 6s won't turn on possible short due to power outage?
Hello all,
So this iphone 6s I have had for a long time. I replaced the screen and other components and it was working fine. Then through a power outage one day the phone would not turn on. I went through the usual initial checks (cables out, anything looked burnt) but nothing. I don’t think its the screen because I just replaced it and when I connect it to my PC there is no read. But when I connect it to a portable battery I can see the battery is pulling power. So I was able to rule out the battery that was faulty, which I also replaced within the year. My question is what to try to troubleshoot so i do not break the bank, my initial thought is replacing the logic board. I do not want to order a ton of parts and break the bank. If anyone has any ideas on how to begin to trouble shoot this, I would really appreciate it. Happy holidays!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The fact that you see a power draw may point to a short too. A bad battery cannot be ruled out either, unless one can make sure it works with tools or tries a known good one. Considering the costs of a microsoldering repair and that of a preowned logic board, that might be the fastest solution if you can find one without too many headaches.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Santiago Correa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 38
