メインコンテンツにスキップ
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969回答 すべてを表示
Screen started doing this, now won't turn back on
Toshiba Satellite L850
I've had the laptop for about 7 years probably, and it's been running pretty well until this happened today.
The screen had some letters all over it and then turned off and showed this a few times and then I force shut it down.
Is this fixable or is it the end?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First thing I would try is connecting it to an external monitor. If the screen on the external monitor works fine, then it could be the cable has came loose or need a new screen. If the external monitor also does the same then it could be something such as a bad driver or bad video card.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Haley L さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 24
