メインコンテンツにスキップ
Apple iPhone や Samsung Galaxy など、すべてのメーカーおよびサービスプロバイダの携帯電話の修理ガイドと分解情報。携帯電話を自分で修理するために必要なものをすべて手に入れることができます。
73642回答 すべてを表示
Why isn't it working?
So I accidently got water in my phone ,then I left it in a bag of rice over night then when I turned it on the next day the screen stayed blank and then it started making ringtone noises and it still won't work…what do I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Rice is for eating, not for drying phones out
さんによる
コメントを追加
2件の回答
One day is not long enough for the water to dry if your phone was in a bag. If you can, try removing the phone’s battery and laying everything in front of a fan so it can dry a bit faster.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you I'll try it x
さんによる
コメントを追加
depending on your phone Rice may not actually do anything at all.
phones these days are compact tightly designed machines and for rice to work it has to come into contact with the water more or less. the water isn’t able to escape towards the rice so it stays in the device.
first step is to remove the battery and clean the motherboard. isopropyl alcohol should be enough if not much corrosion has occurred. when that’s done based on your description you most likely need to replace the screen assembly. of course it’s also possible the water did permanent damage to the display circuit which would require a specialist to fix.
if you give us the model # of your phone it could help us help you as well
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ashia Begum さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 37
