Lightning port bent, iPhone not charging.
My iPhone 8 is not charging. I noticed that the outer housing of the lightning port has bent. I have got the lightning port inside replaced , but the phone still doesn’t charge.
You’ll need to either replace or rework the housing in order to get that working again, I imagine the cable isn’t connecting with the pins inside.
You can just use a wireless charger though…
このアンサーは役に立ちましたか?
I think you can getaway with just replacing the Lightning connector iPhone 8 Lightning Connector Assembly and here's the guide iPhone 8 Lightningコネクタアセンブリの交換 and reshaping the case a bit.
過去 24時間: 2
過去 7 日: 5
過去 30 日: 16
今までの合計 2,370
