メインコンテンツにスキップ
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
35回答 すべてを表示
Why is my screen lit up , but won't let me use the calculator?
I haven’t used my Ti-nspire in a while, and I plugged it in to charge it today and the screen will only light up white. But, I have tried to reset it and also take the battery out and it still won’t work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First, check your battery, make sure it hasn’t corroded or damaged the calculator somehow.
Next, I think your best bet is to try to re-install the OS. There’s a guide on that here: Texas Instruments TI-Nspire CX OS Replacement
If that doesn’t help, try reaching the diagnostics menu or the maintenance menu by following one of these combinations I found on TI-Planet:
3) TI-Nspire CX/CM:
  • [esc]+[menu]+[-]
  • launches the diagnostic software, if present (non-dangerous choice)
  • [doc]+[enter]+[EE]
  • Goes to the Maintenance Menu (allowing you to delete the OS, etc.) (no effect if nothing if cancelled - not dangerous
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Megan Nightengale さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 63
今までの合計 1,824
