メインコンテンツにスキップ
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
27回答 すべてを表示
Why my dodge ram 2001 door speakers don't work and my back ones are st
After market radio no sound up front passenger rear is clear sound but driver side rear is static ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
check loom & harness for any damage first, if none them try this…. there is a built in amp is some dodge trucks, theres a small black wire that goes into the back of the standard stereo that is the negative for the stock amp, you need to feed that into the negative for the aftermarket stereo in the loom. connect the remote amp wires from the stereo to the loom adaptor and connect the power antenna to the switch 12v. try a multimeter if not to check for any faults in the wiring. r install the stock radio again and check if all the speakers work again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
wavy71227 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 36
今までの合計 815
