メインコンテンツにスキップ
Support and repair information for Beats Solo3 headphones.
52回答 すべてを表示
My Beats hinge won't snap back in place
The little hinge on the left side is broken and won’t stay in place.
Anybody know anyways I could fix it without breaking my headphones?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
I’ve had this problem too recently, I figure the problem either lies with the hinge pins or the little clip-like structure that actually snaps it back into place. There’s a small metal structure that you can see the ends of when you snap them out, with two ends on either side facing in that snap in and out of little metal “pockets” on the ear of the headphones. One of the ends may be broken or just bent out of place, so you might be able to just bend one or both of the clips inwards to restore some of the tightness. If a side is broken, you can get a replacement piece at this link. https://www.fixabeat.com/shop/solo/solo3...
The metal piece that is most likely causing the problem would be that little squiggly thing with the crimped ends in the photo.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have the same problem here but in Solo 2 wireless, are these connectors' tabs work with Solo 2 wireless?
さんによる
コメントを追加
回答を追加する
Ryan Kite Smith さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 59
今までの合計 1,054
