メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
1914の回答 すべてを表示
Microphone doesn’t work
My iPhone 7 doesn’t have a working microphone, no sound during video. Alexa in Amazon Alexa app turns on for split sec before it’s gone. when I try to use Siri it activates but it doesn’t hear anything, nor will the voice recorder start.
But when I connect my Bluetooth earbuds ( cheap onn earbuds with mic I think) Siri activated and it can hear me and voice recorder works, but when I record video there’s a greyed out slashed speaker symbol at the bottom. Alexa starts but only turns on for split sec.
also when I try to use lightning port to aux or the apple port earbuds , there’s no sound nor do volume buttons work
pls help
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
A guy at a repair place said it is a software issue, but I’m not sure. I’d like to know first because I really don’t want to have to reset my phone. But if I have to, could I back it up and then restore it from the backup. Could that work?
さんによる
コメントを追加
1 件の回答
選択されたソリューション
When you do calls is the speaker icon greyed out and can't be switched on? Does the phone take like 5 minutes to boot up all the time?
If yes to both it is an audio IC chip fault on the logic board. There are a few pads under the chip that get loose that need to be fixed which connect it to the logic board.
A local reputable phone repair shop that does microsoldering can get this fixed for you.
この回答は役に立ちましたか?
スコア 0
コメント:
Yes, the speaker is sometimes greyed out, the phone used to take 5 min to boot up( it’s the boot loop virus) a restore fixed it
さんによる
Yeah that is the solder balls under audio IC getting intermittently loose.
さんによる
コメントを追加
回答を追加する
Brayden S さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 51
今までの合計 831
