Bottom speaker quite after drop
I dropped my phone and the bottom right screen cracked but I’m not to worried. The thing that I’m worried about is the speaker is now very quiet. What should I do?
Hey!
Sounds more like you need a new speaker.
This is relatively easy to replace, and it doesn't cost that much either.
iFixit also has some guides, as well on youtube.
But there are some tricks that might work!
If the switch appears to be stuck, try to remove any case to make sure nothing blocks the switch. Reboot your iPhone afterwards and test to see if you can now hear sounds coming from your iPhone.
I wish you all the best that you get your sound back again as it should!
このアンサーは役に立ちましたか?
Thank you!!! This worked!! I did a soft reset and then toggled the volume switch on and off a few times. Oh thank you!
過去 24時間: 4
過去 7 日: 24
過去 30 日: 72
今までの合計 3,753
