メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
355回答 すべてを表示
Get a new motherboard?
My RAM is fine, but when it gets seated, very little time passes before the System decides I only have GB. Someone told me that I should replace my motherboard. Does this seem to be a probable solution?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Can you clarify how much RAM you have and what the system reports.
As an example: you put in 8 GB of RAM but only 4 GB is seen.
さんによる
That’s exactly it, Dan I have 8MB installed, but Apple System Profiler says 4MB I was told this means that I need a new motherboard. On a couple of occasions I re-placed the RAM, but after a few days it stops showing in the ASP
さんによる
Ahhh, THAT is what ya call
さんによる
My building-ham radio days were an entire lifetime ago (hopefully it’ll turn out to be half a lifetime...), so as always climbing inside an expensive kit like this is roughly equal to calling that girl back, in terror magnitudes; however, the old digits did remember the fine motor days of yore. Booting in 2, that’s more like it
Thanks again to you, and Props to the tool design crew at iFixit!
さんによる
コメントを追加
1 件の回答
選択されたソリューション
So to clarify your RAM socket lock clips are worn or the socket it’s self is distorted. While a new logic board might help lets see if we can save you a few bucks here.
  • Sometimes wedging a piece of a credit card stock between the socket wall and the clip can force it more forward so the edge of the SO-DIMM is captured.
  • To deal with a distorted socket (the logic board has warped due to heat) try loosing the screws a 1/4 turn.
Update (12/03/2019)
@zalel - Here’s a better view on what’s needed:
このアンサーは役に立ちましたか?
スコア 1
コメント:
Oh, that sounds appealing, I’ll give it a try. My iFixit kit will be Happy to get some attention, too.
Is this the article for me to reference? MacBook Pro 15インチ Unibody 2.53 GHz Mid 2009 RAMの交換
さんによる
コメントを追加
回答を追加する
Nicky さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
