メインコンテンツにスキップ
A 1.9 GHz DECT 6.0 multiple channel handset capable cordless phone, VTech CS6719-2.
9回答 すべてを表示
My phone says to register HS see manual but can't find out how to regi
I de registered my VTech cs6629 but now I can not register it. It continues to attempt to register then says failed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
5 件のコメント
Hi,
Did it work? I have the same issue on my phone since two days and struggling to register my handset with base.
Regards,
Kaushik
さんによる
hi my vtech handset says” fail base full” but only have 6 extensions on the base
it says it can hold 11, please help
さんによる
@dslotman5
What is the model number of the phone?
さんによる
How could I register my vtechphones
さんによる
@lashungprioleau931
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi,
Is the base station powered on?
Did you try placing the handset back into its’ base and then check if it starts to register? The In use light on the base station will being to flash
Try to reset the system by removing the AC power from the base and disconnecting the battery in the handset.
After about 1 minute reconnect the AC power to the base and reconnect the battery in the handset, place the handset in the base and allow a couple of minutes for registration.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
I can't register the 2 table top hand sets. I have registered the wall mount hand set. How do I register table top ones?
さんによる
@Stacey King
Please confirm the make and model number of the base station and all the handsets.
さんによる
it worked for me just fine.
さんによる
@jayeff vtech model CS6829
さんによる
@herbiy
See p.31-32 of the user manual for how to register/de-register handsets and check how that goes.
さんによる
2件以上のコメントを表示
コメントを追加
I just purchased a VTech DS667V-2G with four additional handsets. Only the base station handset registered, all the others continually failed. I finally fixed this by placing each handset on the base station in turn, once on the base station they automatically registered. I then put them in their chargers around the house and they continue to work. It is unclear why this works but not on their own charging stands, but anyone experiencing this issue should try this before calling for tech support, the response on VTech's site is not helpful.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
did not work for me
さんによる
The following worked for me, after an unexpected power outage caused my phones to become "out of range", when power returned....
1. On each phone: De-register from base.
a. Menu (press only once).
b. Press *7890#
c. Select Test Handset > Next Page > Registration Clear > Reg Clear.
d. Remove battery.
2. Unplug the base for a few minutes, then reconnect.
3. Reinsert battery into a phone, and insert phone into main base. After 10-60 seconds, phone should display that it has registered, and date and time needs to be updated. Repeat process for other two phones.
さんによる
コメントを追加
回答を追加する
Rebecca Moreno さん、ありがとうございました!
統計データ:
過去 24時間: 18
過去 7 日: 106
過去 30 日: 392
今までの合計 11,072
