メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
2018 Mini doesn't boot after RAM upgrade
Hello,
I have upgraded my newly purchased Mini to 16GB of memory. This is the memory I purchased:
https://www.amazon.co.uk/gp/product/B071...
Unfortunately my Mini doesn’t seem to boot now :( The LED turns on, but no display is output. Furthermore, after a minute or two I can hear the fans restart and the LED goes off and on so presumably the mini is constantly rebooting.
Firstly, the above memory should be compatible, shouldn’t it? Secondly, does anybody know what I possibly could have done wrong? I’ve no idea what has happened as I thought the upgrade went OK. Is this symptomatic of me forgetting to plug anything back in, for example?
Very sad about this :(
Thanks for any help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Alright, resolved now. Memory wasn’t seated correctly.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for coming back with that update! I was panicking a little after my initial repair attempt was unsuccessful but your comment helped that a lot. I just went in and seated the ram better and it worked like a charm.
さんによる
Same happened to me. The rubber guides on the ram retainers sometimes won't go back to how they were without a little jostling once you have put the new RAM in. After booting to a blank screen; I nervously re opened the mini and checked the seating, now everything is working fine.
さんによる
コメントを追加
回答を追加する
Matthew H さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 35
今までの合計 2,020
