メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1198回答 すべてを表示
Face ID issues after battery replacement (move a little higher/lower)
So after replacing my battery Face ID is no longer able to register my face always saying to move the phone a little higher and then to move the phone a little lower in a loop. I believe the issue is the dot projector. Heres what i’ve tested so far:
  1. putting the original battery back in
  2. cleaning all connectors
  3. reseating back cameras
  4. taking out the sensor module containing the front camera and putting it back in
  5. reseating and cleaning everything on the sensors connected to the screen
  6. called apple support who ran diagnostics and said that they didn’t see any issues with the hardware
  7. cleaned the dot projector with isopropyl alcohol
The front camera and back cameras still work as well as the proximity sensor and ambient light sensor. I also used an old camera to see that the flood illuminator was lighting up. The only thing that refuses to light up is the dot projector. Thanks for the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Rewa has just recently made a video on this. It cannot be fixed by a 3rd repair. You have to go to Apple but even then they won’t work on the phone because you swapped the battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Pls share the video link
さんによる
コメントを追加
Here comes the latest dot projector repair technique for Face ID move iPhone a little lower/higher
iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Taylor Vandenberg さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 55
今までの合計 7,307
