メインコンテンツにスキップ
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52回答 すべてを表示
LCD SCREEN stopped suddenly after hit a splash of sea water
The camera hit a splash of sea water and then appeared on the screen a full blue color and then all the information went gradually then no any thing on lcd screen …. note that the camera is working when I shoot from viewfinder and i replacement LCD to new lcd screen and not solved ..!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
IBRAHIM V.I.P  sounds like water damage to the motherboard since you already replaced the LCD. Use these guides Canon EOS Rebel T3i / 600D to work on your camera. Remove the motherboard and clean everything with 90%+ isopropyl alcohol and a soft brush. Check the board for obviously damaged components etc. If nothing else you can post some images of your motherboard with your Question. That way we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
IBRAHIM V.I.P さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 188
