it goes very loud,PSU is still light green.
after a few minutes,the console goes very loud.can this be fixed?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your fans are probably working overdrive due to overheating of your console. Most likely caused by poor airflow due to dust or previous overheating sessions. It's not a big deal if your game isn't shutting down on you, but it could be a warning sign before a RROD.
I suggest cleaning out the fans and making sure air is able to flow properly through your xbox to prevent it from getting any hotter. Letting it go could cause more problems sooner rather than later.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,189
2 件のコメント
thanks you that information really helps
solomon さんによる
Good luck and happy fragging :)
Derek Halman さんによる
