メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
Outer P5 screw not holding
Hi,
When closing the bottom case of my macbook pro, I noticed one of the 8 P5 3.1mm screw holes does not hold the screw. The problem does not come from the male thread (on the screw itself) because the problem occurs with all 8 of the available screw, but with one specific female thread (the upper-left one next to the screen hinge as seen on enclosed screenshot).
Curiously, I never put too much strength into screwing in a screw.
I did notice when initially opening the device that this precise screw point was a pain to get the screw OUT, not difficult to unscrew, just that the screw would rotate freely without ever rising out of it hole. This leads me to believe the female thread had been previously damaged. (I bought this computer 2nd hand ; the screen had just been replaced with a new one thanks to Apple’s screen peeling-gate program)
Is there a way to correct this issue ? It seems the female thread is in the computer chassis. Does it mean I would have to change the whole f** top case for one problematic screw thread?
Thanks in advance !!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The bottom cover uses two types of screws.
The shorter thread P5 screws go in the two screw holes between the corner screw holes of the top of the bottom case.
The rest are all slightly longer P5 screws so that might be the problem of putting the longer screw in the short hole.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
2 shorter ones, 8 longer ones. I am using a long one. None of the 10 screws hold. It is not related to screw length, but the female threading of the hole being fried I guess. Hence my initial explanation...
さんによる
コメントを追加
回答を追加する
Mighty Sashiman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 116
