メインコンテンツにスキップ
2012年6月12日に発売。Turbo Boost付きのインテルプロセッサー、モデル番号は A1278。
1502回答 すべてを表示
Error "CSSMERR_TP_CERT_NOT_VALID_YET" while install the OS Mavericks
Hello,
I am trying to install a fresh copy of OS-X Mavericks on my 13” MacBook Pro.
I did a bootable USB, but every time I tried to install the OS, it says : “impossible to verify this copy. It has been damaged, or altered during the installation. I tried a different USB, same issue.
So I went to the historic of the installation program. It says
Error : CSSMERR_TP_CERT_NOT_VALID_YET.
Would you have any ideas to help me to have an OS :)
Thank you for your help !
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
It’s probably a time and date induced error because of installer certificates expired. You should try take your clock backwords, but you’ll need to do it from the terminal if you have no OS on your Mac. You can get the correct syntax instructions from here: https://bensmann.no/changing-system-date...
このアンサーは役に立ちましたか?
スコア 3
コメント:
Thank you @arbaman again , i tried to take my clock backwords from the terminal, I tried the date of today, and a random date in 2017. It does'nt work. But the error msg is different :
OS X couldnt be install
the verification or repair of the system failed.
Leave the program of installation to reboot your computer.
It is a progress, we are on the right road :)
さんによる
@anaisrqr Heaven only knows when that certificate expired..I've not installed Mavericks for years at least..never liked it actually :D Pls try Sierra as @danj already recommended..keep us posted..
さんによる
@arbaman Hello, I am writting from the Mac. :) It was complicated, nothing worked, i couldn't install any OS. (high sierra, leopard, el capitan). I couldn't figure out why. Once i was creating the bootable USB, the installation was starting, and at the end a message was popping up again and again saying it was impossible to install the OS, an element was missing.
A friend sold me an SSD harddrive with el capitan on it, and not formated. So i put it inside, and deleted manually everything. Now it is working :)
さんによる
@anaisrqr Strange behavior, but I'm happy you managed somehow to get it back running in the end :)
さんによる
コメントを追加
Here’s a bit more info If you've got an old macOS install image, it will probably stop working today! Apple did release updated macOS’s for Sierra, Hight Sierra & Mojave releases.
Sadly, the older ones were not updated. You’ll need to back date your systems Date & Time setting to a year thats within OS release window.
Follow the guide @arbaman has linked to.
このアンサーは役に立ちましたか?
スコア 2
コメント:
Thank you @danj i followed the guide from @arbaman . But there is an error msg still. But a different one, so it is a progress :)
さんによる
@anaisrqr - Is there a reason you want to stay at Mavericks? How about upgrading to Sierra
Here's a good image file: How to upgrade to macOS Sierra jump to Step 4 for the link. Then setup an OS installer USB thumb drive following this guide How to create a bootable macOS Sierra installer drive and lastly restart your system from the installer pressing the Option key when you restart your system.
さんによる
@danj I have tried Mavericks, and El capitan.
I will try now with SIerra. Thank you for your help. I'll let you know :)
さんによる
@danj Hello, I am writting from the Mac. :) It was complicated, nothing worked, i couldn't install any OS. I couldn't figure out why. Once i was creating the bootable USB, the installation was starting, a the end a message was popping up again and again saying it was impossible to install the OS, an element was missing.
さんによる
@anaisrqr - Happy you're up and running! Sounds like you hit a double whammy!
Besides the OS certificate issue either the HDD was failing or the HD SATA cable your system has is only a SATA II (3.0 Gb/s) and the HDD/SSD you put in was a SATA III (6.0 Gb/s) drive which over stretched the cables ability. Check your system report under 'About This Mac' under the SATA port info tab. I bet you the SATA port speed with be 6.0 Gb/s and the negotiated will be 3.0 Gb/s as the SSD you've put in is an older one.
This cable is a bit fragile too, so you may want to replace it and in doing so you'll get the full ability of what the system can offer! Your Hard Drive Cable Is A Ticking Time Bomb
さんによる
コメントを追加
回答を追加する
Anaïs Rouquier さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 151
