メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Boot Loop after lightning port replacement
Hello,
I just finished a replacement of the lightning port on an iPhone 7. It now attempts to boot but flashes off an immediately back on (like its cycling re-boot sequences. I’ve rechecked that all connections are seated properly.
Here are a couple of small places I feel like it *may* have gone wrong? First, I had trouble plugging the speaker and microphone connections back in place. They are seated now but…that was a challenge. Second, I mistakenly plugged the battery back in before I had re-connected the screen. Could this have shorted a battery connection?
Its not a software issue as iTunes won’t recognize it, nor will my MacBook.
Could it possibly be a logic board malfunction? I’ve read this is common in the iPhone 7 but I don’t have the setup to check or repair a logic board. Is it worth attempting to replace the logic board or….should I just find a used iPhone 7 replacement?
Any suggestions kindly appreciated .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Try booting with the charging port unplugged. If it works unplugged it is a problem with the charging port.
I think there is a quality problem with the replacement charger ports so I always go for OEM or OEM pulls rather than aftermarket because I have had some where they don't align properly to plug into the connector matter what.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the reply. Same affect whether the charge cord is plugged in or not. I had an iPhone 6 do this with bad connections but I'm quite sure everything is seated well this time.
さんによる
コメントを追加
try disconnect the battery n the charger port connector. plug them n try again if it not work this video can help you solve the boot loop https://youtu.be/0XGMFmHLFCw
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ajeet さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 1,568
