Backlight on the left side is out. Model FVD3934
It seems like the backlight on the left side of the screen is out. Model FVD3934. Just wanna know if there’s a way to fix it cheap or if it would be cheaper to just replace it.
BLAST PROCESSING is the left side completely dark it is usually not because of a backlight issue but either a panel, LCD driver or T-con issue etc. You want to post some pictures showing what your display shows as well as your boards and interconnect wiring. If the backlight has failed it is possible that this is related to a bad power board or a failed backlight array (strip). A bad power board would be easiest and straight forward. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
@oldturkey03 I thought I would say hi. you know my personal email address right?
@captainsnowball Hey. welcome back. Yes I do.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 29
1件のコメント
Double check your Sanyo model number since there is no information for that model number
oldturkey03 さんによる
