メインコンテンツにスキップ
Repair guides and troubleshooting for the HP Compaq DC7500, a business class desktop computer introduced in 2007.
25回答 すべてを表示
My pc is not starting just making beeps 9 times with red light blinks
my pc is not starting just constantly beeping for nine times with red light flash again & again. I can’t recognize what problem it has, I watched some videos to fix it on youtube but I find out that my pc is beeping for 9 times all of the videos that I watched on youtube have the solution for 5 beeps none have 9 beep problem solution.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
ベストアンサー
Hi,
Here’s an image taken from page C-11 of the service reference guide for your desktop, which shows what a 9 beep error code can mean.
It could be a faulty PSU so check the various voltages being supplied by the PSU to the motherboard to make sure that they are all OK.
If they are OK then it may be a CPU fault or a motherboard fault.
(click on image to enlarge for better viewing).
Hopefully this is of some help
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
You need to replace supply other wise motherboard need to replace
さんによる
コメントを追加
回答を追加する
Moazzam Ali さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 37
過去 30 日: 173
今までの合計 10,416
