メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
E100 Disc Drive error (Bad disc drive logic board, tried new disc unit
Hello, I have the Big Xbox one (The big black one with the external PSU) and it has the E100 error/brick. I have found that it’s due to the disc drive. I have tried changing the disc drive with the original logic board and it still doesn’t work. If I try and insert a Disc, the Xbox will power up from me inserting the disc, but it won’t actually take it in. If I use the replacement logic board it takes the disc, but ofc I can’t use the replacement logic board because of the pairing. In the log, there is something about ODD not detected or something like that. I don’t know anyone near me that could fix the logic board (think it’s a bad motor controller chip?) so is there anything at all I can do or is the unit now a paperweight. I’ve tried most of the updating techniques. Thanks
(In short, I beleve the motor controller on the odd logic board is dead)
-Marcus
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Marcus,
It may not be the ODD problem. You can check with the original ODD but different HDD.
Could you check if you are able to update the console firmware? I had a similar issue and that was caused by the hard drive.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The ODD doesn't work at all with the original logic board and the logs sat "ODD Not detected" so It's defo the logic board. I have tried the HDD method but it made no change. I've also tried a USB update and it still hangs at the odd error.
さんによる
コメントを追加
回答を追加する
marcus さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,991
