メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
49の回答 すべてを表示
Heat blows cold at idle/rest, and proper hot temp when driving. What
Truck blows cold at idle /still and proper hot temp when driving. What could cause that?
Not low on coolant, System hold pressure. Caps good as well.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Still seems like air in the heater core, very hard to get out. Can you access the 2 heater hoses going into the firewall, one is in and one is out, what I do is locate the out hose, figure out where the heater core metal pipe ends inside the rubber hose and where the clamp seals the hose, pull the hose past this point without totally removing it, drill a small hole in the metal pipe on top to bleed the air out when at higher engine speed but in Park, while filling the radiator at the same time to keep the water level up. once you feel the core is bled, push the rubber hose on and tighten the clamp, this should do it.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tyler さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 9
