メインコンテンツにスキップ
このモデルは2016年に発売されました。2013年に発売されたCUH-ZCT1に変わる後継機です。コントローラーは前モデルと類似しています。
266回答 すべてを表示
I broke both my PS4 controllers, they won't charge nor turn on
Hi,
it all started when I got frustrated and broke the triggers on one controller, I have two controllers so it wasn’t the biggest issue. I just opened up my other controller and took the triggers which I then put back into my broken controller.
However, after doing this n’either of the controllers will turn on or charge anymore. It can’t really be a battery issue, the ribbon cable is also in for both the touchpad and the back of the PS4.
Any suggestions I could have broken ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Maybe that’s a stupid question, but did you reassembled them correctly? If they are not turning on nor charging it may indicate that the battery is not connected to the logic board.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
yeah I think I have, I mean - there's not much I can do wrong when assembling it. I just tried my controller and it was on for a short moment but is dead again
さんによる
@Vizzy Maybe ribbon cable is loose or something like that?
さんによる
https://i.imgur.com/GfTSQHi.jpg
That’s how it’s been ensembled..
Edit: that one now works for some reason, although the mic port is screwed.. the other still ain't working however.
Edit: it now no longer works, it stopped working when I put pressure on the controller trying to screw in the screws.
さんによる
コメントを追加
回答を追加する
Vizzy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 78
