hello can I fix vertical line 4 inch going from top to bottom?
I replaced logic board because I thought it caused problem but please look at the pictures
there is 4 inch line going from top to bottom is it LCD or connector cables inside?
This looks like a messed up T-CON board issue which is on the backside of the LDC panel. Here’s the P/N for the full display Apple P/N 661-5542. Here’s one source 661-5542 Apple LCD Display for 27" LED Cinema Display. I haven’t used them let so let us know if you have any issues.
このアンサーは役に立ちましたか?
thank you ! I will buy it and replace
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 83
@miksuiek75 - Here's how to post the pics iFixitでの質問に画像を追加する方法
Dan さんによる
just replaced T-CONE did not work, still same strap 4 inch going from top to bottom
need help
Michael Niedzwiadek さんによる
I am thinking may it be video cable connector?
need help, T-Con board was replaced and same nothing changed
