メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Joystick not reading Y axis after replacing stick and solder
I recently got an XBox controller, and its joystick was drifting on the Y axis. I bought a new one on eBay and tried to solder on a new one. This was my first time doing this, so I don’t know if I did it correctly. Now the controller doesn’t read the Y axis at all. Is there still hope for this controller?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
@jkcoxson since this happened after you repaired it you want to check a few things. Check to make sure that your analog stick actually works. You can measure it with the ohm settings in your multimeter. After that you want to take a look at your repair. Check the solder to make sure it is properly known to the connectors and the solder pads and make sure that you have not lifted any of the solder pads. Personally I would redo the repair with a new stick and a clean the board properly with some flux and desoldering wick etc. before resoldering a new stick. Watch the heat and the duration that your are on the board with yours soldering iron. Looks kind of black burned on the north end of the board….;-) Make sure you did not smoke the other components that are on the board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Did you ever figure out what the issue was? I just repaired my bingos switch power A joystick, or replaced rather, and it no longer reads the Y axis. It was havingdrift issues, I swapped out the left and right joystick, the left works great the right also worlds to look left and right with no drift but you can’t look up and down. I thought maybe it was a defective joystick so I swapped it out with another and same issue. I’m wondering if I might have accidentally desolderd one of those tiny resistors and it just disappeared since it’s so %#*@ small. Can anyone show me a pictures of a power A switch controller on the right thumb stick so I can see what is missing if anything?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jackson Coxson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 2,050
