Cracked Glass on phone
Only the glass is cracked. The LCD screen is perfect just can't use phone due to glass cracked and cuts finger.
You can just get a glass only repair done so that the screen will be separated from the cracked glass and a new one would be installed. Or you can get a whole screen replacement that would replace the glass and screen. If you want to be cheap you could always put some clear tape over the glass until you get it replaced?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 387
