My Ipad air 2 screen comes off
Hi,
After having the display and the battery on my ipad air 2 replaced (by a repair shop) it slowly comes off. I brought it back the first time and when they gave it back (today) it was already coming off again. At that point they gave me my money back and said it can’t be fixed.
Obviously I’m a little afraid they did something wrong that can’t be repaired…
Anyway, now I’d like to fix it myself since I’m familiar whit these kind of work.
Can you suggest a good procedure to remove the old tape/glue (should I use acetone?), is there something in particular I should be careful because it may be the cause of the coming off of the display?
Here are some pictures of the ipad (notice that I just got it back, I’m quite sure that it will come off more in a day or two).
Also, it seems that they used some glue, while they told me they used tape (a 3M branded tape).
2 件のコメント
In addition to the answer provided by Kevin, check all 4 sides of aluminum frame (corners as well) and straighten them out if they are bent/warped, a bent sidewall will cause screen to not sit flush and slowly come off over time.
Gorilla さんによる
Thanks Sammy. I'll be sure to look at that too... I really hope they didn't damage the frame, it already seems they did a very poor job :(
Carmine さんによる
