メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
73の回答 すべてを表示
After a screen replacement.. A very thin black line on the left
Hello Ifixit community! Pleasure to ask a first question in the forum. Yesterday, I attempted my first self screen replacement ever, with a screen (without the metal shield) I ordered from Repair Union, a popular Chinese company that sells phone parts. The Iphone XR I had was bought from Ebay, and it worked with no problem, except for a cracked screen. So, I attempted to replace the screen, following the Ifixit guide. When I was done with everything but closing the screen, I made sure the touch worked by dragging an app everywhere on the screen. I don’t know if this line was there then, but my guess would be if it wasn’t there, I think I would have known. Anyways, I went ahead and closed the phone tight. And I think this is when I applied a glass screen protector.
When I turned on the phone, I found white pressure spots on the right corner area of the phone. At this time, I’m not sure if the line was here or not. But if it was, I would have thought the line was an edge of the screen protector.
Anyway, I was busy researching online why these spots were here, snd after several attempts of repair, and by finally re-installing the metal shield, I could fix the screen like a magic. I was so happy.
After that, I thought all was good, still thinking the line was an edge of my glass screen protector.
After awhile, I was annoyed by this line. I believed it was because of the screen protector, but I didn’t want to take it off, because I felt bad about wasting it. But after some consideration, I decided to take it off to enjoy the smooth and raw original screen. When I took the screen protector, the line remained. At first, I thought taking off the screen protector damaged the screen. But later I found that the screen protector was actually big enough to cover the full lighted screen.
So here I am, with an almost perfect brand-new original screen, with a very thine black line by the left bezel. Since I was so excited about getting a new screen and using this phone, and watched more than fifty videos preparing to attempt self-repair for the time, I am disappointed. So I am here wondering if anyone who is more experienced than I am could give me advice to let me know anything that can enlighten me.
I’m wondering, if this can be a result of flex cable damage. I did put pressure on the flex cables, as I tried to get rid of glues on the back of the flex cables for the LCD and digitizer.
Or, could it be something else, such as, dirty connectors?
I did try reinstalling the LCD and digitizer, but no luck.
I don’t understand why, and how, a single, very thin line can appear like this. Could you let me know all the possibilities?
I’m desperately wanting to hear any possible solutions.
I know it’s not a big issue, but the line still bothers me, since the screen was said to be brand-new original. And the hard part is that I don’t remember if the line was there at first, which makes it hard for me to know if this screen came with the line from the beginning. Please help! Thank you.
+By the way, I used a cutter knife the open the screen. And I noticed that because of doing that multiple times, I scratched off a bit the bottom of the back of the screen’s display cable. It reveals bits of gold-yellow metal. Could this be the reason?
+ Also, i broke the small bracket (picture) attached to the logic board connector bracket. Could this be the reason for the line?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Your problem is that you ordered a screen from China instead of a reputable supplier of DIY parts like iFixit.[br]
[br]
Seriously—you use iFixit’s guide to install the screen. You are using iFixit’s forum to ask questions—-both of those things require money to develop and maintain. You know that iFixit pays for these things by selling screens—-so you take your money and give it to Union Repair?[br]
[br]
That’s really not cool, and you reap what you sow. You either damaged the screen or it was defective.[br]
If you had bought it from iFixit, you might get a replacement since they are DIY friendly. Union Repair will not replace that screen—so live with it or buy one from iFixit like you should have to begin with.[br]
さんによる
That's very rude and mean of you to leave a response like that here. I didn't ask for your preaching.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Its an issue with the screen try to return it.
この回答は役に立ちましたか?
スコア 1
コメント:
how can you be sure?
さんによる
Get another screen and see if the same issue happens.
さんによる
コメントを追加
回答を追加する
BKimc さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 56
