Will not advance past wash cycle
Model 110.92593220
Completes wash cycle but stops before rinse cycle with tub full of water.
Will work if I manually advance the timer.
I have replaced -
timer 2x
pump
control board
water level switch
transmission and clutch
I have checked the continuity of the lid switch.
I have almost replaced everything and it’s still doing it!
(@jayeff - I replied to your questions on my earlier post but it was removed as spam - I have addressed your questions in this post)
この質問は役に立ちましたか?
2 件のコメント
Unfortunately it’s not the lid switch
I did replace it and also tested the new one.
It spins when the timer is manually advanced.
David さんによる
Hi @david777 ,
Don't know your washer but have you tried both hot and cold wash cycles and all wash cycle modes to check if the problem occurs?
Can't find a wiring diagram but you may have to prove continuity in the wires from the timer, especially from the timer contact that is used when it goes to start agitating again after filling at the start of the rinse cycle.
I assume that this is what you meant when you said "...stops before rinse cycle with tub full of water.", i.e. water drains at end of wash cycle, tub refills a start of rinse cycle .
Or did you mean stops at end of wash cycle and doesn't drain and advance to refill for rinse cycle?
jayeff さんによる
