Where can I find a logic board?
I have an iTouch 3g 32gb that has a small burned spot on the logic board. I want to replace the board. Where can I find one?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Andrew, I think you may be better off buying a new iPod (or used) than replacing the logic board. Could you post a picture of the damage?
このアンサーは役に立ちましたか?
Can't post pic since the iTouch is all back together and I did not do the work in the first place. I have decided to not worry about it unless the thing completely goes dead. I am able to use it like I did in the first place. I bought it used for $50, knowing the back light did not work.
If you have a local repair shop, they may be willing to give you a little something for the parts. (Just a thought)
try to use a good search engine like Google and you will find them on places like this. Not cheap but available. Also try ebay.com and see what you come up with. good Luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,036
