メインコンテンツにスキップ
HPのベーシックモデルのインクジェットプリンター、DestJetの修理用ガイドならびにサポート情報です。
105回答 すべてを表示
HP 2512: not feeding paper, rollers aren't moving
My printer is no longer feeding paper when a single sheet is loaded or a stack. It makes a sound like it’s trying to feed the paper, but when I shine a light down into the printer, I do not see that the light gray rollers are rotating when the printer rests them against the paper.
I saw a similar issue (and fix involving epoxy) for a Deskjet that has a horizontal tray, but mine has a vertical tray so I imagine the fix will be a bit different if there is one. Thanks to anyone who has a solution here.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Opened her up with the help of this YouTube video (getting the display panel off was a trick!). https://www.youtube.com/watch?v=rmwYDBrj.... I found a broken off cog (white) and post (tiny black) that I’m attempting to glue back into place. The missing cog caused a disconnect between the other moving cogs and the feeder roller. Fingers crossed here. Also, I cut a window/hole in the back right side of the printer body to access the site. I wasn’t about to take the whole inside apart!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mimy Bailey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 267
