Where is WiFi Antenna? Replacement?
Hi! I’ve got a Xiaomi Redmi 5 Plus and the WiFi signal is very very very poor, I have to be next to the router to connect…
Where are the WiFi antenna located? Can I change it?
Thanks!
Hi @pmpa97,
The antenna may be just loose from the systemboard or have a bad connection. Try re-seating the antenna cable into the connector.
Here’s an image taken from a Xiamio Redmi 5 Plus teardown video, showing the WiFi antenna connection location on the systemboard.
(Click on image to enlarge for better viewing)
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,169
