No power to control panel after using oven.
How do you unlock a locked control panel on a GE Home Microwave?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The display panel tells you what button/s to press and for how long. Problem is, it is written in very small letters. I use a flashlight to find it, and of course, I have to put on my readers. Getting old isn’t for the weak.
このアンサーは役に立ちましたか?
Hi @janjones999
Based on fixya comments,
Had you tried this method?
http://www.fixya.com/support/t26900218-u...
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 84
