メインコンテンツにスキップ
エレガントなデザイン、長いバッテリー寿命、および同様の価格のノートブックを凌駕するパフォーマンスを組み合わせたIdeaPad 120sは、コストパフォーマンスに優れています。 Lenovoの110シリーズに続き、2017年に発売されたLenovoは、これまでになく楽しいユーザーエクスペリエンスを提供しています。
6回答 すべてを表示
Notebook doesn`t boot up without a charger plugged in
Hello.
First of all, my notebook is the Lenovo 510s-13IKB, but I could not find that one in the selection.
I have a weird problem, where I can`t start my notebook anymore without the charger being plugged into it. I already tried to hard-reset it, took out the battery, held the start-button ec. Now normally if I start it up with the charger, boot into windows but then remove it, the notebook shuts down. But weirdly enough I noticed, that when I go into the boot-menu, bios or start up Ubuntu and then remove the charger, it does not shut down. Then again, if it goes to sleep or shuts down again I won`t be able to start it up again without the charger.
I`m out of ideas at this point, hoping for help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @hawkisdead ,
As a first step I suggest that you check if the battery is charging properly when the charger is connected.
If not the battery may need replacing.
Here’s a link to the service manual for your model Ideapad.
Scroll to p.21-22 to view the procedures for checking the charging and the battery pack.
Scroll to p.35 to view the necessary pre-requisite steps and then the procedure to remove/replace the battery pack.
On p.70 item #11 you’ll find the part numbers for all the batteries available for your particular model Ideapad. Searching online using the part number only will give results for suppliers of the part.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I checked things mentioned in the service manual, the battery charges like it's supposed to. I can still remove the charger after I've been in the boot menu, and even restart it via Windows/Ubuntu options. It just doesn't start up initially without the charger.
さんによる
Hi @hawkisdead ,
Just a different tack.
Try starting the laptop using a standalone program on a bootable USB stick e.g. this one. You'll have to change the boot menu of course so you may have to try it a few times to get the scenario where you made it fail before, i.e. turn off the power after you've been in BIOS and it has started etc. and then see if it fails or not
I'm not suggesting that it is a memory problem by using the program above.
All I'm proposing is that you try to start the laptop without resorting to using the OS installed on the HDD. Perhaps even consider disconnecting the HDD
Other than that perhaps you may have to change the battery just to definitely eliminate it as the problem. Strange things can happen when you have power problems
さんによる
コメントを追加
回答を追加する
Chris Miller さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 330
